Lifter roller squeel
Old Apr 6, 2009 | 07:47 AM
MD83Z's Avatar
Can a lifter roller intermittenly squeel like the sound of a water pump bearing ? This is on a factory roller cam engine with possible dexcoolant damage. If left to squeel, (usually at below 1,000 rpm) can it freeze up and destroy the cam? Thanks for any help.
Old Apr 6, 2009 | 11:37 AM
Damon's Avatar
Re: Lifter roller squeel
Not that I've ever heard. If the lifter roller chews itself to pieces it has the common decency to do it quietly until the point of catastrophic failure.
Old Apr 6, 2009 | 11:45 AM
MD83Z's Avatar
Thanks for the info...guess we will see when the top end comes back off again.
Old Apr 6, 2009 | 12:53 PM
MD83Z's Avatar
Ugh....could cam berings sqeel only at low rpm....it gives a slow eek sound when shut off. Any thoughts are apreciated! A lifter or rocker tapped at first start up, then went away, now the screech, from that side.
KO1
16
Oct 15, 2015 05:00 PM
skinny z
Oct 5, 2015 06:23 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
