USing stock fuel pump for carb pickup???
Old Apr 6, 2009 | 07:37 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
Im swapping from TBI to carb and am going to be using a mechanical fuel pump instead of an in-line electric and was wondering if it is possible to use my stock fuel pump as a pickup for the mechanical fuel pump instead of removing the tank to install an aftermarket pickup in the tank?
Old Apr 6, 2009 | 08:21 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: USing stock fuel pump for carb pickup???
Why not use a regulator and keep electric pump and return line? Works great.
Holley bypass regulaor Jegs part#510-12-803BP. You can adjust pressure at the carb from 4.5-9psi.A dynamic(return type system) system responds faster to fuel demand and does a better jobkeeping the float bowl full in track and street applications.
I've done some research on this subject and all the pros recomend dynamic over static(non-return) systems. There is a good article on fuel delivery systems in the new June issue of Chevy High Performance. I've run this system for 7,000 miles now w/ no problems or worries.
Old Apr 6, 2009 | 08:30 PM
Engine: Vortec 357
do you know where i can get this dynamic return type system your talking about. Im very new to carbs and dont know exaclty what to buy for the setup. I planned on using stock fuel lines with a regulator and bypass for the return line.
Old Apr 6, 2009 | 08:47 PM
J91's Avatar
J91
Your system is dynamic, all I am saying is keep the electric fuel pump, run a bypass regulator between 5-6 lbs of pressure. Run your feed line from the tank into the regulator. Return line back to tank and the regulated line to carb. I ran my stock pressurised rubber hoses (had to buy a couple of threaded fittings) and return right in/out of the regulator.
If you go mechanical there is no return line back to tank. Also this way you can keep the stock fuel line ventilation system(cannister) in place.
The Holley regulator I mentioned has complete easy instructions for installation it costs $68.00...
Old Apr 6, 2009 | 09:31 PM
Engine: Vortec 357
oh ok i see what your saying now. Now in order to run the stock fuel pump i need to run a hotwire from the ingition correct, so when i turn the key it still turns the pump on instead of the computer doing it?
Old Apr 7, 2009 | 05:16 AM
J91's Avatar
J91
Yes , you could do that, I would put a kill switch on it though. There is a good instructional thread, on changing over to carbs on here. You should read it, it answers many questions. You can pickup the wire under the drivers side door sill.
Look under tech articles in the Carb-EFI section, it's one of the first articles has everything you need! Keep me posted I'll help if I can....
Old Apr 7, 2009 | 05:27 AM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
or you can just get a mechanical pump on the side of your engine. run your fuel line to it, and a line to your carb. there is no return line. disable your old pump in the tank and never worry about changing fuel pumps in the tank for the rest of your cars life. cost 18 bucks at any local auto parts store.
Frozer!!!
Jan 19, 2024 04:55 PM
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
