Replacing a cam and Lifters
Old Apr 7, 2009 | 12:58 PM
meduv6269's Avatar
I have been told and its makes perfect sense that a used camshaft and its lifters are consider one set after being broken in (a couple thousand miles?). Should I even consider buying a camshaft with 3,000 miles and install it with brand new lifters?!?!?!?!?!?!
Old Apr 7, 2009 | 01:06 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: Replacing a cam and Lifters
what kind of cam....flat tappet or roller?? roller you can just put the lifters in and it's fine....flat tappet the lifters need to be put back in the same place they came out...I believe if their not marked buy new lifters, and break it in..... Are you buying a aftermarket cam of a factory cam??? If you have the ability or know someone that has the ability, you should degree the cam....I've seen many cams ground off center and you have to advance or retard them to get them "straight up"....I put a crane cam in a car recently that was ground 8 degrees retarded..so we had to advance it 8 deg. to get it where it supposed to be. Comp cams, so far, have always been right on.....if you don't have the equipement to do that you most likely are probably going to be fine, and I wouldn't worry to much about it....just some info for ya.
Old Apr 7, 2009 | 03:36 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Take a look at it. If no lobes are obviously worn, then it'll be fine with new lifters, or better yet, the old lifters, put in the right holes.
If the lobes look slightly worn, it's fine. A brand new cam loses it's coating in 20 minutes of break in, then looks (and works) the same for about 150,000 miles before you start losing lift due to wear.
sweet_87_iroc
Sep 25, 2015 10:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
cstrobel65
Aug 15, 2015 10:19 AM
Fronzizzle
Aug 9, 2015 01:15 PM
drathaar907
Aug 6, 2015 04:20 PM
