heads for 400 sbc?
Old Apr 8, 2009 | 06:28 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Transmission: 700R4,700R4
Axle/Gears: LSD,LSD
heads for 400 sbc?
i can get my hands on a 400 short block and am wondering what heads would be okay to slap on there for now..some that are readily available and perform decent that i can find for pretty cheap...and holes for power steering pump..any help will be great!!!!
Old Apr 8, 2009 | 09:02 PM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
Re: heads for 400 sbc?
anybody??? please???
Old Apr 8, 2009 | 11:18 PM
toomany's Avatar
A set of Vortec heads would be a good choice. Good bang for the buck there. Look for casting numbers, 12558062 or 10239906. About $600 for new ones at a dealer or through Summit or Jegs. If you've got some cash to blow...get a set of AFR's. Steam holes would probably need to be drilled in almost any head you buy.
Old Apr 8, 2009 | 11:46 PM
bart91406's Avatar
Car: 91 rs
Engine: 383 290 cam aed carb
Transmission: th350
Axle/Gears: 4.10 ticking time bomb
Well, a good head for a 406 is not quite enough info, if it is a stock rebuild, then any stock 350 head will work fine just as long as you drill the steam holes.
if it is built, then vortecs are a good bang for the buck, but how about a little more info on the shortblock, and your budget, that way we can give you an educated answer.
Mickeyruder
Sep 2, 2015 02:45 PM
camaro71633
Sep 1, 2015 10:24 AM
lakeffect2
Aug 23, 2015 08:44 AM
theurge
Aug 21, 2015 12:46 PM
