Where does egr solenoid mount to?
Old Apr 10, 2009 | 01:58 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Where is the egr solenoid suppose to be mounted to on an 89 tpi car? I can't remember where it came from, right now I have it mounted opposite the ignition coil on the same bracket. Is that where it's suppose to be?
Old Apr 10, 2009 | 02:02 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Where does egr solenoid mount to?
Yes it mounts to the same bracket as the ignition coil.
Old Apr 10, 2009 | 02:09 AM
89RsPower!'s Avatar
Thanks, that's what I thought since it was the only thing I could see with the same bolt spacing. Trying to make sure I put everything back where it goes.. Now if I could only figure out where that 4 foot long vaccum line with the T at the end of it that T's off of the HVAC vac supply goes.. I'm assuming it goes to the cruise control somewhere but I can't find an empty port anywhere on it..
Old Apr 10, 2009 | 02:55 AM
Kevin91Z's Avatar
On mine it goes behind the engine, along the driver's side fender and T's off to the big cruise control "ball" and to the charcoal cannister.
J-money
Jan 4, 2019 09:45 AM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
rjcme
Sep 5, 2015 01:23 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
