Can I put these heads on my car
Old Apr 10, 2009 | 09:31 AM
quickbrad's Avatar
Car: 86 IROC
Engine: 355 TPI
Transmission: JUNK
I have 383 eagle rotating asmbly, with lt4 cam, flat-tops- tpi-- 26# injectors-- slp runners.. The heads are Brodix 221 cc intake runners-64 cc-2.05/1.60.. what should it run like and what should I expect over a set of stock l98 heads???
Old Apr 11, 2009 | 12:32 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Can I put these heads on my car
64cc on a flat top 383 will put you around 10.9:1. Your cam was probably cheap, but is very tame. 221cc heads will work up to 7000 rpm, so no using the stock TPI manifold on top. Best to run either a Victor Jr. for carbureted or a TPIS Mini-Ram for EFI. And change the cam. then you could see 500 horses with 1.75" headers and a single 3" exhaust won't flow enough.
If 7000 rpm isn't what you want, sell those heads and get some AFR 195s. The 75cc version should give you around 9.9:1, and this would work up to 6500 rpm. Still would want a cam change.
As it stands, you have a mis-matched combination.
Old Apr 11, 2009 | 06:26 PM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Mismatched combonations will work against you. Before picking a cam, get the flow rates and choose your cam from there.
Old Apr 12, 2009 | 08:44 PM
quickbrad's Avatar
Car: 86 IROC
Engine: 355 TPI
Transmission: JUNK
Cool thanks for the info on the brodix,,,,, what about Vortec?????????
Old Apr 13, 2009 | 12:16 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The 170cc, casting numbers 062 and 906, Vortec 350 truck heads, on a 383, will be all done by 5500 rpm. They are a much better match for your cam, and for TPI. But Edelbrock's E-Tec heads are lighter by about 25 pounds each.
CRFred
Feb 7, 2016 11:39 PM
1nastygta
Oct 28, 2015 08:51 PM
86IROC112
Aug 17, 2015 02:00 PM
anesthes
Aug 8, 2015 09:37 PM
