Royal Purple Gear Lube Oil
Old Apr 10, 2009 | 02:26 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
GM recommends 80w, 80W90 GL5 gear lube, + GM additive #1052271 for limited slip differentials for my KITT. I want to use Royal Purple 75w90 Gear lube to my rear end, will it screw up my rear end? Should I add the additive or not? or use something else?
Old Apr 10, 2009 | 03:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
75W-90 is fine. Use the posi additive if your posi makes noise going around corners. Adding it before you know it makes noise is fine as well.
Old Apr 10, 2009 | 04:52 PM
danandamy's Avatar
Car: 86 Camaro
Re: Royal Purple Gear Lube Oil
Royal Purple has the additive built in. Just pour it in and go.
Dan
Old Apr 10, 2009 | 05:35 PM
KITT1983's Avatar
Dan
Did you use Royal Purple before and did you use the GM additive?
Old Apr 10, 2009 | 06:17 PM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
I have been using royal purple for all applications, in all my vehicles. I am running it in my 88 bird, and i did not use any additives. I have the 3.08 W/ posi and it has been fine. I don't have any whining that i have heard about on these cars.
Old Apr 11, 2009 | 09:51 AM
danandamy's Avatar
Car: 86 Camaro
www.royalpurple.com/gear-oil.html
Old Apr 29, 2009 | 05:42 AM
KITT1983's Avatar
thanks dan
gixxer92
Sep 1, 2015 04:32 PM
Navy8125
Aug 21, 2015 09:32 AM
Navy8125
Aug 17, 2015 01:29 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
