R-4 compressor install, how much oil to use?
Old Apr 12, 2009 | 01:11 AM
tomcat128's Avatar
Car: 1988 Pontiac Trans Am
Engine: L98, built to 383
Axle/Gears: 3.78
I am getting around to fixing my a/c today and am putting it back together, but I can not find anywhere the proper amount of oil to use when replacing the compressor, evaporator, and accumulator. I know to drain the old compressor and use that amount in the new one but I did not have an old one to drain. This also would not give me the right amount if I had the old compressor because I am replacing the accumulator and evaporator. If anyone know what the factory spec is for the amount of oil for the system I would be grateful.
Old Aug 14, 2009 | 10:25 PM
Bradlyj8Z28's Avatar
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
Re: R-4 compressor install, how much oil to use?
just wondering if you ever got this sorted out?
Old Aug 17, 2009 | 05:53 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
total a/c oil system capacity is 8 ounces. depending on how long the the system hasn't been used the oil will sit in different places, low spots mainly. you can average it out to 1.75 ounces compressor, 1.75 ounces condenser, 1.75 ounces evaporator, 1.75 ounces accumulator 1 ounce in the lines.
toronto formula
Nov 10, 2015 06:17 AM
TheExaminer
Aug 25, 2015 07:34 PM
Navy8125
Aug 21, 2015 09:32 AM
rh76camaro
Aug 15, 2015 12:48 PM
drathaar907
Aug 6, 2015 04:20 PM
