Misfire, Plug Reading Help!
Old Apr 12, 2009 | 01:58 PM
dan_t's Avatar
Car: C4 Vette
Engine: Gas Guzzler
Transmission: ZF-6 Manual
Axle/Gears: 3.75
I'm really stuck with this! I'm running out of idea's to try so ANY help would be REALLY appreciated!
Full engine spec:
Scat 383 Bottom End / AFR 195 Heads / Felpro 1010 Head Gaskets / 9.5:1 Compression / LT1 Intake & Fuel Rails / 30lb Injectors / Stock TB / Comp Cams 306 / 74deg Overlap / 230/244@.050 / ZF-6 Manual / Singlemass Flywheel / Hedman Headers / LT1 Exhaust / Small Distributor & External Coil
Now I've had a pretty major time trying to DIY tune this on a daily driver basis - WOT it pulls like a train and always has.
As the tune is getting closer I'm realising that I've actally got a misfire at light throttle/cruise. Its most noticeable as I get above 2000 rpm. It sounds like its just a single cylinder and its rather random, almost like morse code. Its not enough to cause the engine to stumble, but I can hear it and it just kinda "tugs" like lope.
I have just pulled the plugs (well 7 as the last is a PITA) and they are all so mixed!
Driver Bank: Porcelain / Strap
Plug 1: Light Tan / Tan
Plug 3: Brilliant Clean White / Tan
Plug 5: Tan / Tan
Plug 7: Black / Black
Passenger Bank: Porcelain / Strap
Plug 2: Dark Tan / Tan
Plug 4: NA / NA
Plug 6: Light Tan / Tan
Plug 8: Black / Black
I know that plug reading is more involved than this but I was rather shocked to see such varrying results - especially plug 3 in which the pircelain looked brand new, not a singe mark on it.
I will try some new leads, the Cap and Rotor are new. Its had a fresh set of plugs now. The only other thing I can think of is the injectors are not flowing equally? How can I test this? Any other ideas???
PLEASE HELP BEFORE I GO MAD!!!
Old Apr 12, 2009 | 05:48 PM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Re: Misfire, Plug Reading Help!
Bring your plugs to NAPA and have the injectors cleaned and flow tested. They do this for a small charge (not sure how much). Better than replacing them all if they are good to begin with and just need cleaning. What is going on with plug #4? Black plugs are not good either.
eightsixseven
Dec 16, 2024 01:50 PM
Thornburg
Aug 30, 2015 08:05 AM
mdtoren
Aug 23, 2015 12:52 PM
db057
Aug 22, 2015 08:17 PM
mdtoren
Aug 16, 2015 05:45 PM
