VORTEC HEAD VALVE SPRING QUESTION
Old Apr 13, 2009 | 09:33 PM
1985IrocZ's Avatar
Car: 1985 Z28
Quich question, I have vortec heads on my 305 with 062 casting number. My question is simple. I've noticed that my heads have dual valve-springs. Does that mean that the springs have been beefed up by the previous owner???.....or does Vortec heads with the same casting number automatically comes with dual valve-springs????
My second question is the following: with the dual valve springs, does this mean I can run a wilder cam with out having to worry about valve float????
Thanks for the info.
Old Apr 13, 2009 | 11:05 PM
the zander's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 TPI (retrofit)
Axle/Gears: Crappy stock 10-bolt gears
Re: VORTEC HEAD VALVE SPRING QUESTION
As far as i know, 062 Vortecs were never equipped with dual valve springs. The valve guide bosses are typically around 0.850" in diameter which prevents the use of dual springs. That means your heads must have been machined previously to accept those springs. Depending on the springs, you could have a very capable set of heads. You should also take the time to measure the maximum lift to determine the cams available to you.
-Z
Old Apr 13, 2009 | 11:15 PM
1985IrocZ's Avatar
Car: 1985 Z28
And how would I go about figuring that out????....the lift I mean????
-Z
Old Apr 14, 2009 | 12:37 AM
the zander's Avatar
Do you have the tools necessary to remove the valve springs? The most accurate method involves removing the springs, reinstalling the retainer and locks on the valve stem, and using a dial gauge to measure the total travel. keep in mind a 0.060" safety margin is recommended by most manufactures. I can go into more detail if you would like, not sure of your skill/experience.
-Z
Old Apr 14, 2009 | 03:23 AM
1985IrocZ's Avatar
Car: 1985 Z28
No it's ok, I understand. Only one thing though, when I get that distance of the valve travel, will this mean that the lift of the cam wont be able to surpass it???
Old Apr 14, 2009 | 09:59 AM
the zander's Avatar
Correct, if the total travel you measure is, for example, 0.550" - 0.060" = 0.490". In this case you could only consider cams with lifts (at the valve) of less than 0.490". Post the result of your measurements and we can help reccomend a cam.
-Z
Old Apr 15, 2009 | 10:57 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Dont forget to check for spring bind.
Old Apr 15, 2009 | 06:39 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I'm running 062 heads and comps 918 beehive springs on my Vortec heads with the .525 Lift LT4 hotcam No issues. The beehives alow more lift due to a thinner retainer.
Old Apr 19, 2009 | 11:59 AM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
these the springs your running: http://store.summitracing.com/partde...5&autoview=sku
you using screw in studs?
im considering the same setup.
Old Apr 19, 2009 | 12:01 PM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
double post
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
gta90
Sep 15, 2015 04:00 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
