Quick question on Fuel Pressure Reg.
Old Apr 17, 2009 | 12:50 PM
Rally Smith's Avatar
Car: 91 RS
Engine: 305 TBI
Axle/Gears: Factory 2.73 (unfortunately)
I searched an didn't find anything that answered this question. I am going to put on an adjustable pressure regulator with the adapter and gauge. How do I adjust the pressure? Is it set at idle or wot or what?
Thanks,
RS
Old Apr 17, 2009 | 01:43 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: Quick question on Fuel Pressure Reg.
it is set at idle, with the vacuum line off...set to 43.5psi...there little screw head on the end of where you hook your vacuum line to...you turn that to adjust pressure...
Old Apr 17, 2009 | 01:48 PM
Car: 91 RS
Engine: 305 TBI
Great, thank you 91, but are you talking about TPI? I have a TBI, I thought that the pressure should be set at 12 psi?
I'm confused....
Old May 4, 2009 | 10:10 AM
Car: 91 RS
Engine: 305 TBI
Is there a way to tell what pressure I should set it at with the winald program on my laptop? Or is there an easier/better way to do that?
Thanks,
MustangBeater20
Oct 29, 2022 09:20 PM
Infested
May 22, 2018 11:56 PM
R3500
Aug 17, 2015 12:16 PM
happyhapka
Aug 15, 2015 04:42 PM
Kaweh
Aug 9, 2015 02:54 PM
