Oil leak
Old Apr 17, 2009 | 12:47 PM
4yoto24's Avatar
Car: 84 camaro berlimetta
Engine: 305 5.0
Oil leak
ok check it out, i just got a an 84 camaro , with a 5.0 305 h.o engine. the problem is that its leaking oil in various spots, i need help with this can i have suggestions, i know its not the place to post this issue up, but i need help. thx
Old Apr 18, 2009 | 12:05 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
No, posting in someone else's thread with your problem is not the right thing to do.
Now you have a thread of your own.
But, you aren't going to get much help with the way you worded it. Are you expecting a list of all possible places oil can leak? Why don't you just start by telling us where you're seeing the leaks.
Old Apr 18, 2009 | 11:11 AM
4yoto24's Avatar
Engine: 305 5.0
Re: Oil leak
oh okay sorry is just that im new in this website and im still getting acustomed. well i got various leaks, but they are all small. im worried about one, its on the drivers side in the front.
Old Apr 18, 2009 | 03:48 PM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
Re: Oil leak
Sounds like either the timing cover gasket, or the seal in the cover where the balancer attaches to the crank. The latter is press fit- you can knock it out w/ a socket and a BFH, and it installs the same way.
Easiest way to eliminate them ALL is to use a Fel Pro 1 pc oil pan gasket, and replace the timing cover gasket/balancer seal.
Otherwise, just do the tc gasket/balancer seal, and RTV the crap out of the corners.
Old Apr 18, 2009 | 03:50 PM
4yoto24's Avatar
Engine: 305 5.0
Re: Oil leak
ok thank you very much, so its not so expensive?
Old Apr 18, 2009 | 07:26 PM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Re: Oil leak
Depends....do you have a balancer puller, and installer? Otherwise the gasket kit is pretty cheap.
Also, if you are doing the oil pan as well, the 1 pc gasket costs about 40, but is worth every penny.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
