I need an iroc-z owner to test something for me
Old Apr 18, 2009 | 05:12 PM
Synful's Avatar
If you have an 87-89 iroc-z 305 or 350 tpi with MAF system, mostly stock, I please ask you to test something.
Others can chime in if they have opinions on hypothetically what should happen:
Unplug all of the injectors' electrical connectors. Try to start the car. What happens? Crank only? Small fire then die?
Old Apr 18, 2009 | 06:03 PM
Vader's Avatar
Re: I need an iroc-z owner to test something for me
If the coolant is below 104º, there should be a short shot of priming fuel from the cold start system. This might provide enough fuel for a few cylinders to fire.
Unplugging the injectors isn't necessary. You would only need to remove the INJ1 and INJ2 fuses.
Old Apr 18, 2009 | 08:46 PM
Synful's Avatar
So hypothetically, if I unplug the cold start injector AND all 8 regular injectors, the car should NOT fire at all, after maybe a few fires to purge the residual fuel?
Old Apr 18, 2009 | 09:04 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
or just disconnect the coil...
what are you getting at?
are you trying to keep the car from starting?
Old Apr 19, 2009 | 03:01 AM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
if the car does start with the injctors unpluged you have some bad injectors. i dont know if thats what you are looking for but whats the problem your having
Old Apr 19, 2009 | 02:37 PM
Synful's Avatar
I've been having an issue with my car (detailed out in another thread in this forum) and wanted a way to see if my injectors were leaking without having to remove them
Old Apr 19, 2009 | 05:13 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
you can just put a fuel pressure gauge on it, cycle the ignition on, and if it drops off, thats your problem.
Old Apr 19, 2009 | 05:14 PM
3rdgengmachine's Avatar
Car: 87 iroc z
Engine: 358 tpi
Transmission: 700r4 with transpack
Axle/Gears: 3.42 with powertrax
i have an 87 and noticed one day while changing my plugs they had fuel all over them and when i shut it off and tryed to start it back a few mins later i had to crank and crank it b4 it would start the injectors were leaking fuel when i shut it off flooding it out i put in a new set of venoms and it starts great every time
Old Apr 19, 2009 | 10:23 PM
Synful's Avatar
It doesn't drop off it remains constant.
At one point I had a consistant 60psi for some reason but aside from that one random time it is always 40psi, unless the car is actually firing in which case it drops off by 5psi.
Is there a way to determine whether or not the ECM is bad by directly testing it? I don't have a scan tool or laptop to plug-in. Is there a practical way to determine it?
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Fronzizzle
Sep 8, 2015 12:10 PM
84 TA NV
Sep 6, 2015 08:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
