1987 Trans Am Shutting Down when I Let Off The Gas
Old Apr 18, 2009 | 08:30 PM
jkrustchinsky's Avatar
Car: 1982 Trans Am, 1986 Gmc sierra
My 87 TPI motor is starting to give me trouble. When the motor is warm, it wants to bog out and die if i let off the accelerator. If i give it a little gas before it dies it will run at about 400 rpm when idling. It has a full tune up done recently. Where should i start troubleshooting. Thanks, Josh
Old Apr 19, 2009 | 09:11 AM
Vader's Avatar
Re: 1987 Trans Am Shutting Down when I Let Off The Gas
Start looking at the throttle body, IAC passages, and IAC for buildup of varnish. Verify the TPS voltage while you're there.
Old Apr 19, 2009 | 09:14 AM
WSX123's Avatar
Car: 1988 Trans Am GTA
i agree with vader I had the same issue, the right mechanic can do a good flush and clean all the crap out of it.
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
beachrodder
Aug 25, 2015 08:05 AM
wayshegoes
Aug 17, 2015 12:00 PM
