why not place an AFPR directly after the fuel pump?
Car: 86 Camaro IROC-Z
Engine: 305 TPI (retrofit)
Axle/Gears: Crappy stock 10-bolt gears
Perhaps I'm overlooking something obvious, but why shouldn't i install my AFPR directly following the external EFI fuel pump. The pump is located 1' forward of the tank, under the trunk space. I seems to me that placing it here would save a whole lot of tubing by shortening, almost eliminating, the return line. From there i would only have to run one high-pressure line to my TBI unit.
Aside from the less convenient adjustment, what other drawbacks can you imagine might exist?
-Zander
-Zander
Transmission: 4L80E/4L80E
You could. That's what they did with LS1's after a year or two.
Advantage of having the reg up by the engine is you don't have slow-moving fuel picking up heat along the way. If the reg is up by the engine, you'll have fuel moving quickly meaning it'll have less time in the line to pick up heat.
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
