CAR DOESN"T STALL WITH EST CONNECTOR DISCONNECTED
Old Apr 20, 2009 | 12:38 AM
Dean_GTA's Avatar
Car: 1988 TA GTA
Engine: L98 Replaced w/ 350/330HP W/TPI
Transmission: Stock 700r4
Axle/Gears: stock 3:27
Hi, My 1988 Trans Am 350 TPI, idles and runs fine with the EST wire disconnected. When the wire is connected, the car idles rough and stalls when put in reverse or drive. I've tried 2 different distributors and I still have the same problem. Can anybody help?
Old Apr 20, 2009 | 09:53 AM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
Re: CAR DOESN"T STALL WITH EST CONNECTOR DISCONNECTED
try a new ecm
Old Apr 20, 2009 | 09:55 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
check your base timing stock is 6 degrees before.
Old Apr 20, 2009 | 10:40 AM
Vortex91's Avatar
Car: Camaro RS '91
Engine: 305 TBI
Transmission: Auto w/ TransGo shift kit
Hey Dean, did you rebuild the MSD distributor with new parts from MSD?
D.
Old Apr 20, 2009 | 01:20 PM
Dean_GTA's Avatar
Car: 1988 TA GTA
Base timing is set to 6* before with the EST wire disconnected. With the wire connected it advances to about 16*+ & - but it's not a smooth idle.
Old Apr 21, 2009 | 12:55 PM
kcallais's Avatar
Car: 1985 Z28
Youve tried different dizzys with the same result. Its runs just fine with the EST disconnected you said. The only difference between EST connected and not, is connected the ECM drives the advance/retard function. Try a different ecm/prom.
Ghettobird52
Jul 5, 2024 11:18 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
TreDeClaw
Aug 14, 2015 06:58 PM
