putting roller set up into a pre 87 block
Old Apr 20, 2009 | 05:30 AM
white85transam's Avatar
Car: 85 trans am
Engine: 383 stroker
Transmission: 5 speed
Axle/Gears: 9 bolt rear 3:70
was thinking of going roller but dont know exactly what i may need to do. can anyone tell me. or point me in the right direction. thanx
Old Apr 20, 2009 | 08:31 AM
sccavette's Avatar
Car: 85 Corvette, 91 Trans Am
Engine: V8
Axle/Gears: round ones!
Re: putting roller set up into a pre 87 block
There is 2 ways to do what you want!
1. Have the block machined at the lifter pockets and drilled and tapped for the retainer. if you look at the top of the lifter bores on a early and pate block you will see the difference. I do not suggest doing it this way!
2. Go with a roller lifter setup that is designed for a early block. here is a link to a set for a BB, you can find the ones that you need for your motor however this will give you a idea what you are looking for.
http://www.jegs.com/i/Comp+Cams/249/854-16/10002/-1
Old Apr 20, 2009 | 10:23 AM
Car: 85 trans am
Engine: 383 stroker
does anyone know how strong and reliable those retro fit rollers are? do those links ever break?
Old Apr 20, 2009 | 02:04 PM
sccavette's Avatar
Engine: V8
I used them once in a 84 Camaro 355 I built some years back and did not have any problems. I think the ones I used were from Crane. I have never heard of any failing. How many RPM's you plan on turning thie motor?
Old Apr 20, 2009 | 02:08 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
retro fit roller lifters, and cam lock plate so the cam doesnt walk. i roller'd my 78 big block.
Old Apr 20, 2009 | 03:03 PM
Car: 85 trans am
Engine: 383 stroker
i dont plan going anything past 6200-6500 rpm. with this motor and approx. 500hp is what is expected. i am trying to get a feel for their longevity. and want to make sure that they areny prone to breaking. if they are i will stay flat tappet and take my chances that way but if i can go roller i will. how does everyone feel about using slightly used roller lifters on a new cam?
Jake_92RS
Jan 28, 2020 10:37 PM
midge54
Dec 27, 2019 04:14 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
camaro71633
Sep 1, 2015 10:24 AM
anesthes
Aug 8, 2015 09:37 PM
