no grip for shizit
Old Apr 20, 2009 | 10:33 AM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
no grip for shizit
whats the best way to "hookup" using stock gears and non posi rearend? ill take off from the line and just spin, and hitting the bottle makes me peel out even worse. any ideas?
Old Apr 20, 2009 | 10:38 AM
Stephen's Avatar
Car: 87 GTA
Re: no grip for shizit
A posi or limited slip center section would be the best option. Even a sticky (one) in an open rear probably wouldn't do as good as a posi or limited slip center section.
Short of that, its just a matter of ROLLING into the throttle, not overpowering the tire & not STABBING it to the floor.
Old Apr 20, 2009 | 11:30 AM
Engine: 355
ya it suxs cant grip for nuttin. what year camaro comes with the posi rearend? whats a good one but not real expensive?
Old Apr 20, 2009 | 11:40 AM
matj1990's Avatar
Car: 83 firebird/camaro conversion
Engine: carbed 350 very mild build
Transmission: th350
Axle/Gears: 3.42 posi
i got a 97 rear end and its full posi no grip launch issues here everyone takes off spinning from a stop light i just launch
Old Apr 20, 2009 | 12:29 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
lol im visualizing ONE slick/DR on a car hahaha thanks that just made my day.
to the op, a posi rear end is your best first step, then some sticky tires
Old Apr 20, 2009 | 01:10 PM
Engine: 355
how hard was that to mock up to your car? any issues or bolt straight up?
Old Apr 20, 2009 | 03:37 PM
matj1990's Avatar
Transmission: th350
i didnt install it myself i had my mechanic do it since he already had the car on the lift for the tranny rebuild but its pretty much swap and play although your going to need brakes from the 4th gen becuase the 3rds wont fit
Old Apr 20, 2009 | 03:41 PM
Stephen's Avatar
Car: 87 GTA
......although your going to need brakes from the 4th gen becuase the 3rds wont fit
I don't quite understand you......
4th gen rears are a DIRECT bolt-in, other than the E-brake cables. Don't hafta do anything to the brakes, master cylinder, booster....Nothing.
Old Apr 20, 2009 | 03:54 PM
matj1990's Avatar
Transmission: th350
im talking calipers and rotors wont fit u need them from a 4th gen idk about e-brake since myn isnt hooked up everything else will be fine
Old Apr 20, 2009 | 04:11 PM
Engine: 355
how do i tell what rearend i got? my door tag got painted over and dunno how else to tell
Old Apr 20, 2009 | 04:34 PM
Stephen's Avatar
Car: 87 GTA
OK, but I thought the PBR calipers & rotors were the same, from 89-97?
Look at the center section cover.....9 bolt heads = a 9-bolt &, you guessed it....10 bolt heads = a 10-bolt. Only 2 options there were (except the RARE Dana 44 under the Firehawks)
Old Apr 20, 2009 | 04:42 PM
Engine: 355
i found my rpo codes under the consile lid, it has gu5, 3.23 gear but cant tell if its posi or not
Old Apr 20, 2009 | 05:55 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Look at your skid marks, if there's two of 'em it's a posi :P
ctoledo0834
Sep 18, 2015 04:16 PM
83 Crossfire TA
Sep 18, 2015 12:01 PM
Fox118
Sep 12, 2015 09:29 PM
Dialed_In
Aug 20, 2015 01:45 PM
86FyrBrd
Aug 4, 2001 09:55 AM
