Roller rocker question
Old Apr 21, 2009 | 11:43 AM
leek157's Avatar
Car: 95 SHO. 87 IROC red 69 Vette blue
Engine: 3.0 Yamahammer.5.7 TPI L98, 350
Transmission: mtx4 ,700r4, 4speed,
Axle/Gears: 3.27, 3.73
I know this is probably a dumb question that I will probably end up answering my self but I'll ask it anyway to be sure. When I'm installing my roller rockers do I just put them on the stud or do I use that Washer type thing with the hemispherical shape on the one side (I don't know the specific name for the piece) I can get a picture If it is needed.
Old Apr 21, 2009 | 11:59 AM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: Roller rocker question
just rockers and must have LOCKING NUT....you also need self-aligning rockers or pushrod guides.Also you must tighten the nuts on roller rockers accoding to instructions...usually 1/2 turn past touching pushrod....do a search on adjusting roller rockers for more details. also...did you get roller tip or full roller rockers??? because roller tip should be same as stock. hope that helps a little
Old Apr 21, 2009 | 12:07 PM
leek157's Avatar
I went back out and looked at them I figured it out, ya they are self aligning full roller thanks for the help and the quick reply.
Old Apr 21, 2009 | 12:10 PM
Engine: L98 494hp
make sure the nut touches the flat part of roller....the rounded part faces down...
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
