Does anyone know how to pick out pistons?
Old Apr 23, 2009 | 03:59 AM
thunder-lips's Avatar
Car: 1989 Formula 350
Engine: building a 383 as of Feb. 09
Transmission: 700 R4, B&M shift kit
Axle/Gears: 3.23?
And I thought picking out a cam was hard!! There is almost no info on the web that guides me to a decision. I need help!!
383 build, 64cc heads, needs to run on pump gas so 10 or under compression, right. I will be running 150 shot of nos from time to time so will go with forged.
So what do I do? Just buy pistons with 10 or under compression? What is up with the skirts? Are Keith Black Good pistons?
Old Apr 24, 2009 | 06:38 PM
Axle/Gears: 3.23?
Re: Does anyone know how to pick out pistons?
anyone?
Old Apr 24, 2009 | 07:05 PM
skinny z's Avatar
I would venture to say that any brand name aftermarket piston will give you want you want.
Pick your desired compression ratio and work the formula to arrive at a suitable valve relief/piston dish volume.
Check out this link to Federal Mogul. You can browse through the listing and get a general idea what pistons give approximately what compression ratio. You can then use the standard comp ratio calculators to zero in on exactly what will work.
http://www.power-21.com/federalmogulpower21i/
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
ALIENhumanoid
Members Camaros
80
Apr 23, 2016 11:35 PM
BBSDesigns
Sep 22, 2015 03:08 PM
Mongoose462ci
Sep 16, 2015 11:46 PM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
