tpi sensors
Old Apr 26, 2009 | 11:50 PM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
tpi sensors
i have a 350tpi camaro its been sitting for about 5 years it runs ok a little shitty just trying to diagnose some problems. first what sensors are on this motor and what would the symptoms be if their bad.
Old Apr 26, 2009 | 11:53 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: tpi sensors
Sensors should be the least of your problems. SES light is it off???? Can you pull any codes (short pins A&B on ALDL)???
Check simple stuff first = ignition, fuel pressure, hoses, bad gas...
//RF
Old Apr 27, 2009 | 03:07 PM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
Re: tpi sensors
i used the scanner no codes at all. new gas good fuel pressure how do i test ignition the module and coil are new
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
