Sucking to much air
Old Apr 28, 2009 | 04:11 PM
1990Phoenix's Avatar
Sucking to much air
unfortunatly i only have a little 3.1L V6...lol.... but as soon as i get the money thats gone... nyways.... im haveing a problem keeping it running because the throttle body is sucking WAY to much air.... it will only consistantly run wen someone puts their hand over the mouth n regulates the air it sucks in that way....soooo.... if nyone has an idea wats goin on...id greatly appreciate it... thank you
Old Apr 28, 2009 | 06:38 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Sucking to much air
Check out the IAC valve. Its workes like a controlled vacuum leak past the butterfly to keep the car running at idle and if it were to fail could cause what your describing.
Old Apr 28, 2009 | 06:40 PM
CBR1000RR's Avatar
Car: 91 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: 10 bolt 3.73's
, and welcome to the board.
Bubbajones_ya
Jul 6, 2024 08:32 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
355tpipickup
Sep 13, 2015 11:35 PM
edoff13
Sep 11, 2015 03:55 AM
luvofjah
Sep 10, 2015 10:41 AM
