I need advice please 1,5 or 1,6 roller rockers
Car: Trans am GTA 1990
Engine: 383
Transmission: TH700R4
Axle/Gears: stock
I have the following parts:
Csb 350
Edelbrock RPM heads 6089 gasket ported
Comp cam xr276HR-12 (224 int./230 exh @0.50 503 510)
HSR 24lb
Hooker 2055 magnaflow hiflow cat and 3" catback
The heads flows
100 67/58
200 130/108
300 183/144
400 226/169
500 229/175
600 232/182
Would I gain anything by using 1,6 roller rockets instead of 1.5 or does my head flow to little? any1 that has the same setup that has tested 1,5 and 1,6?
Csb 350
HSR 24lb
The heads flows
100 67/58
200 130/108
300 183/144
400 226/169
500 229/175
600 232/182
Transmission: 4L80E/4L80E
If you already have 1.5:1 rockers, it wouldn't be much of a gain to go to 1.6:1.
If you don't have any rockers yet, 1.6:1's wouldn't hurt you, and probably won't cost much if anything more, so go ahead.
Engine: 383
Axle/Gears: stock
Re: I need advice please 1,5 or 1,6 roller rockers
I have them both but my cam lifts 503, 510 with 1.5 and at that point my head flows (only) 229/175, if I use 1,6 the lift are 536, 544 and at that point my head probably flows 230/178 something so its not that much different, If my heads had flowed 240-245/180-190 I had allready installed the 1,6 but now I dont know but I hope you do, and can guide me to the right track.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
There's more to it than that. For one, a couple of years back the world finally accepted the discovery that it is better to have relatively more agressive intale valve action than exhaust valve action, and newer cam grinds reflect this. There is a lot of merit to using 1.6:1 for the intakes and 1.5:1 for the exhausts. Also, using 1.6:1 on your intakes is more for 2 other advantages, not to get more peak lift/flow. One is that you reach the higher lifts slightly quicker, where there is more airflow, and the other is you stay there slightly longer. Your 224 duration is what the valve sees with 1.5:1, will instead be seen as 226 if you use the 1.6:1. That, plus learning you already having both sets, is why I'm now suggesting you run 1.6:1 intake and 1.5:1 exhaust.
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
I agree. Go with 1.6 on intake and 1.5 on exhaust. The split sets cost alittle more though.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
