Where to Find: Vacuum Tubing?
Old Apr 30, 2009 | 08:41 AM
milleym's Avatar
Car: 1986 Firebird S/E
Engine: 2.8L 173cid V6 MFI
Hi All -
While I was working to repair the crumbling head gaskets in my '86 Firebird (2.8L v6), I inadvertantly broke off some small, black, firm plastic tubing--I'm assuming it's Vacuum tubing--running off and around the EGR valve.
The trouble is that I'm having trouble viding a vendor that sells this stuff--rockauto.com, 1A Auto, Hawks THird Gen--nobody seems to sell it, or at least, no one seems to sell it seperately.
Here are my questions: Can I buy this? If so what is it called? Does it come bundled with another part? Are people still making it, or should I go Junkyard diving? Is there some sort of geeric tubing that I can use? Can I simply repair the tubing with superglue?
Thanks for your help,
-Mark
Attached Thumbnails Where to Find: Vacuum Tubing?-04-27-09_0846.jpg
Old Apr 30, 2009 | 11:06 AM
dr.fiero's Avatar
Car: '91 S10 Blazer
Engine: TBI 350
Axle/Gears: 3.73 posi
Re: Where to Find: Vacuum Tubing?
Super common problem on all GM's. That damn hard plastic tubing cracks and causes grief all over the place.
All is not lost though!
Just keep about 1" of plastic pipe at the end of the rubber nipple, then hit up NAPA and buy a few feet of various sizes you need (just measure the OD of your various pipes). Slip the rubber hose over the cut off tube, and route in the original (or close) space.
It comes in MANY small steps (sizes), so don't try to guess.
I've got piles of each (there's about 10 from like 2 to 12mm) since I do it all the time.
It's fairly cheap for the smaller stuff (~$1/ft)
Old Apr 30, 2009 | 12:24 PM
milleym's Avatar
Great, thanks! What's OD? Outer Diameter?
Old Apr 30, 2009 | 01:16 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
They sell the hard plastic tubes at advance auto. Probably at all the parts chain stores. Sometimes it's hidden in an aisle you wouldn't expect, sometimes near the pcv grommets and oil plugs and stuff.
Old Apr 30, 2009 | 08:02 PM
dr.fiero's Avatar
Car: '91 S10 Blazer
Engine: TBI 350
Yes -- Or Outside diameter.
And sure, you might be able to find new plastic tubing, but... it cracked once, why put in what will just do it again? Also, unless it's a straight run... how easy is it to form?
Old Apr 30, 2009 | 10:23 PM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
I agree very easy to kink that stuff. Also if you're replacing vacuum lines you might want to pick up an assortment of plastic fittings. They get brittle and crack just like the hose.
Old May 11, 2009 | 02:19 PM
florida_gators's Avatar
Car: 1990 Firebird
Autozone. Brought in the old pieces and they matched the size up and cut to fit.
Old Jun 9, 2009 | 11:46 PM
Mutant's Avatar
I am not sure if the vacuum lines are the same as the Fiero 2.8 V6 vacuum lines but if they are this site has some nice steal vacuum lines for a good price. Knowing GM I will bet they are the same lots of other parts are inter changeable.
http://www.rodneydickman.com/retail.html
Look under Engine/V6 under manifold vacuum lines, they look the same to me but I have a 350 so I could be wrong.
Rodney might know if they will work try emailing him.
I hope this helps
Pac J
May 17, 2020 10:44 AM
gixxer92
May 18, 2017 11:20 AM
no green
Jan 9, 2016 09:22 PM
FormulasOnly
Oct 2, 2015 05:52 PM
zman1969
Oct 1, 2015 11:09 AM
