roller cam question?
Old May 2, 2009 | 04:42 PM
white85transam's Avatar
Car: 85 trans am
Engine: 383 stroker
Transmission: 5 speed
Axle/Gears: 9 bolt rear 3:70
this is going to be my first roller cam i have installed and want to make sure i do it right. i was told i need a thrust button and retainer plate and a wear plate is that right? also how do i know exactly what i need and how to shim it? how do i know what thickness wear plate to get? i have purchased the comp cams xr294hr-10. this is also a retro fit i am doing.
Old May 2, 2009 | 07:36 PM
Sooner's Avatar
Car: 1982 4cyl 4spd/ 1980 z28
Re: roller cam question?
The eaisest way I know to do it, is to knock out your back cam plug and
set up the dial indicator to read on the back side of the cam. You want
around .010. you will need a stiff timing cover as well, beacuse a stock
one will often flex while trying to set endplay and your readings will be all
over the place.
Old May 2, 2009 | 08:02 PM
Car: 85 trans am
Engine: 383 stroker
what do you do if the motor is still in the car?
Old May 3, 2009 | 01:46 AM
Sooner's Avatar
A two peice timing cover would be the easiest.......
http://cgi.ebay.com/ebaymotors/Cloye...4506.m20.l1116
I guess you could do the 'ol tootsie roll trick, like when you check piston
to valve clearance. Take all the washers off of the cam button and install
it. then take a tootsie roll and smash it a little bit then use some scotch
tape to attach it to inside of timing cover where it will contact cam
button upon installation. put gasket on timing cover and then push timing
cover down on to dowels and as far as it will go onto block. Remove
cover, carefully take tootsie roll off of inside of cover, then put tootsie roll
in your freezer for 30min or so to make it hard. after 30 min or so, you
measure your squished tootsie roll with a set of dial calipers and it should
give you the dead nuts measurement.
your timing cover gasket should be roughly .010 or so thick, so if you can
get your timing cover to barely contact cam button without gasket on,
you should be in the ballpark.
Old May 3, 2009 | 07:23 AM
Car: 85 trans am
Engine: 383 stroker
that info helps alot i didnt think of that. i like that cover too but its a little expensive but i might just have to spend we'll see. thanx
Old May 3, 2009 | 02:10 PM
Sooner's Avatar
Im sure that there are other methods out there for in-car roller cam button setup, but those two are all I could think of. Good luck!
junkcltr
Aug 2, 2019 11:12 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
anesthes
Aug 8, 2015 09:37 PM
