1989 gta not going up or down. New motors
Old May 2, 2009 | 08:08 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
So replaced my headlight motors this morning with rebuilt ones. So i know the motors are good and the nylon gears inside are good. I think it my be a headlight moduale. were is it located. is it on my driverside firewall? which one is it? any pics or info would be great.
Old May 3, 2009 | 09:51 PM
Guest
Guest
Posts: n/a
Re: 1989 gta not going up or down. New motors
No pics, but its between the brake booster and wiper motor. That may be the problem. I recently took one apart and one of the wires inside the relay itself was a cold solder and was no longer making a good connection. Fixed that, good to go. Maybe you'll get lucky and can fix it instead of replace it. Cant hurt to test it out and see if its sending power and if not try to fix it.
89GTAOz
May 16, 2020 09:31 AM
Andrew6.688
Dec 13, 2015 10:59 AM
kyleb24
Aug 15, 2015 08:24 AM
stalkier
Aug 13, 2015 12:59 PM
NBrehm
Aug 5, 2015 07:57 PM
