timing cover thick enough?
Old May 3, 2009 | 08:09 AM
white85transam's Avatar
Car: 85 trans am
Engine: 383 stroker
Transmission: 5 speed
Axle/Gears: 9 bolt rear 3:70
i was looking at this timing cover and was thinking it may flex with a roller cam but was wondering if anyone has used this with a roller cam and had any problems.
http://store.summitracing.com/partde...2&autoview=sku
it says you have to use a nylon button and it is only .090" thick.
Old May 4, 2009 | 12:01 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: timing cover thick enough?
http://store.summitracing.com/compar...4294840140+115
Old May 4, 2009 | 02:53 PM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
I am sure it would be thick enough. You could also use a edelbrock aluminum water pump with the adjustable stud to get finger tight to the cover as well to keep it from flexing. Here's the cover I used http://store.summitracing.com/partde...1&autoview=sku I liked it because of the adjustable cam button so I could get the cam just right in the block(retrofit roller) and also used the edelbrock pump just in case, that and it looks nice when done.
Old May 4, 2009 | 03:05 PM
Car: 85 trans am
Engine: 383 stroker
how does the cam button adjust and what is the part number on that pump? was it short or long? i have everything set for a long pump. having a hard time finding that pump with an adjustable stud.
Old May 4, 2009 | 03:35 PM
Car: 85 trans am
Engine: 383 stroker
also did you use any kind of wear plate or did you just use that cover other than that stud?
just trying to order parts and want to make sure i have everything i need in order to put it all back together once it is apart. so far all i have is the cam, lifters and timing gears.
Old May 4, 2009 | 03:46 PM
dellman83Z's Avatar
the pump part number is 8811 for the long version, which is most common. I did not use a wear plate because you have to machine the block some I guess to use one. The button adjusts by turning a little screw on the front of the cover to move it in and out. When you get it right, just take off part of the cover and hold the button and then tighten the screw down to keep it in place. Worked pretty slick for me. As long as you got the right lifters, you should be set fot all the timing components. Did you get the right size push rods because the stock length will be wrong with the retrofit lifters.
Old May 4, 2009 | 03:51 PM
Car: 85 trans am
Engine: 383 stroker
for push rods i got the comp cams .100 long i think
i got the comp xr294 retro grind and the crane retro hyd. roller lifters and the push rods are comp part number 7957-16
Old May 4, 2009 | 03:55 PM
dellman83Z's Avatar
7.1 long you mean, those would be right if I remember correct.
Old May 4, 2009 | 03:59 PM
Car: 85 trans am
Engine: 383 stroker
where does that stud go into the pump? the pic at summit doesnt really explain or mention the stud. is the stud something that can go on any pump? also the length on those rods are 7.150
Old May 4, 2009 | 04:04 PM
dellman83Z's Avatar
The rods should be ok, and the stud goes in the center of the pump at the bottom of it. Its a basic stud that threads through a small tab at the bottom and locks in with a nut when tight. That stud will go right to the cover, right in the center where the cam would be.
Old May 4, 2009 | 04:22 PM
Car: 85 trans am
Engine: 383 stroker
ok i see where it goes now the pump i was going to use doesnt have it and the edelbrock is quite expensive. is there another way to reincorce the cam or is that cloyes cover strong enough?
Old May 6, 2009 | 02:53 PM
dellman83Z's Avatar
I'm sure the cloyes is thick enough. That thing is pretty beefy, even the removable plate. Sorry it took me a while to reply back, I was away from my computer.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
NinjaNife
Aug 23, 2015 11:49 AM
