91 lo3 problem
Old May 3, 2009 | 01:50 PM
tibbitt23451's Avatar
Car: 1991 Camaro RS
Engine: 406
Transmission: t5
Axle/Gears: 373
91 lo3 problem
I have no top end, it hesitates on hard acceleration. I put a new fuel pump in about 2 weeks ago with new filter, it ran great for about 1 week. I cut the panel above the fuel pump so i would not have to drop tank and i repaired fuel lines with clamps & rubber hoses. If it idles well but hesitates upon acceleration should it be a fuel problem?
Old May 3, 2009 | 05:07 PM
Car: 1991 Camaro RS
Engine: 406
Transmission: t5
Axle/Gears: 373
Re: 91 lo3 problem
Please help
Old May 3, 2009 | 06:08 PM
bitchin_buick's Avatar
Car: 91' bird(WS6>>305TBI), 82'Regal
Re: 91 lo3 problem
Did you recheck all your clamps/connections? what fuel pressure are you running?
Old May 3, 2009 | 08:18 PM
Car: 1991 Camaro RS
Engine: 406
Transmission: t5
Axle/Gears: 373
Re: 91 lo3 problem
I did check the clamps. The main fuel line is a little tweaked The rubber hose I used). I think I used 5/16 hose on all lines but my neighbor thinks I need 3/8 on the main line does anybody know what size line it is?
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
