Help car wont start!
Old May 3, 2009 | 08:43 PM
GIJason91's Avatar
Car: 1991 Camaro RS
Engine: 5.7 350 TBI
Transmission: M5
i installed a new fuel pump and new msd ignition among other things in my freshened up 1987 350 tpi. i have spark to the plugs and fuel to the fuel rails i can even smell gas on the fresh never ran plugs! the engine will crank but it wont give me even a hesitation or any combustion at all. could my timing be that far off to not get any combustion what so ever? i pretty much killed a brand new optima red top battery just trying to start it through all these issues ive been having so i have very little start left till i gotta recharge the thing in a different car. any ideas anyone? i cut out a buncha stuff including all emissions equipment(air, egr, fuel canister) if anyone has ideas let me know. thanks!
Old May 4, 2009 | 10:13 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Help car wont start!
Sounds like you are either way out on the timing or your plug wires are on the cap wrong.
Hope this helps.
Old May 4, 2009 | 10:27 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Also when you freshened up your 350 did you set the valve lash right ? You may not be getting compression due to the valves hanging open .
Old May 4, 2009 | 06:41 PM
GIJason91's Avatar
Car: 1991 Camaro RS
Engine: 5.7 350 TBI
Transmission: M5
well its not that fresh, new gasket set and heads but they were an old set up my dad was using so i didnt mess with them. i got it to fire up for a second and it sounded really strong i just couldnt get it to stay running im pretty sure i just have to play with the cap for a while. thanks
Old May 7, 2009 | 08:11 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Keep us posted .
Old May 18, 2009 | 07:41 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Did you get it yet ?
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
