Motor Mount Issues
Old May 3, 2009 | 10:04 PM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
Motor Mount Issues
Im haveing issues getting to the motor mount nuts , The lca is in the way , does anybody have any tips on how to get to them?
Old May 4, 2009 | 03:06 AM
Chilekesh's Avatar
Car: '89 Trans Am GTA
Engine: L98 - 350 TPI
Axle/Gears: 3.27 BW 9 Bolt
Re: Motor Mount Issues
Replaced motor mounts with poly just yesterday. Use a swivel joint and a 20> cm extension. If the joint is not stiff enough to stay still, use some tape. You can reach the nuts through the gap near front A-Arm mount with a socket. Fix the socket from the bottom, turn from the top. They're all 15 mm in my car. When installing back, again use a tape to fix the washer and nut to each other and to the socket. Be careful not to drop them into the K-member frame, might be hard to get them back.
Old May 4, 2009 | 07:47 AM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
ok thanks that should help quite a bit . I was considering dropping the Aarm.
Old May 11, 2009 | 09:43 AM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
So i got the drivers side off . Now for the Passenger side it looks to be alot more difficult.
Old May 11, 2009 | 10:04 AM
Chilekesh's Avatar
Also, don't panic if the motor doesn't fall back flush with the new mounts. Even 1 mm is enough for it to remain stuck on one side, polyurethane is a pretty strong material and just the friction with the bracket can hold the engine up. Just raise and drop the engine a few times (slowly of course) and lightly hammer the bracket on the side that's stuck. It'll fall easily with the weight of the engine helping.
Frozer!!!
Jan 19, 2024 04:55 PM
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
