Intermitted no spark at coil.
Old May 4, 2009 | 10:19 AM
89RESTO's Avatar
2011 Norwood Gathering
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
Where should I start troubleshooting? My car ( 89 iroc 5.7 ) died while at idle, I checked for spark at the plugs... no spark, no spark at the coil either. So I hooked up a new coil and it starts right up, take it for a drive and 10 minutes later the car died again, I checked for spark and nothing, I hooked up the old coil and the car started right up. So if it's not the coil is it possible the ecm is bad?
Old May 4, 2009 | 10:33 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Re: Intermitted no spark at coil.
I would have the ignition module checked and check your pickup coil in the distributor .
Old May 4, 2009 | 02:52 PM
GadeXTrigger's Avatar
Car: 91 Camaro
Engine: 5.7Fl V8 350 tpi
Transmission: 700R4 Automatic
bro mine died at idle and i changed the ignition coil and still no spark so could it be the pickup coil in the dist? because i thought it might have been the ignition switch? could it be that?
Old May 5, 2009 | 07:22 AM
89RESTO's Avatar
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Do the ignition module and pick up coil regulate spark to the plugs or does one of them provide power to the coil?
Old May 7, 2009 | 08:16 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
The pickup is for identifying which cylinder is up for ignition and the control module reads the info from the pickup and the computer to tell the coil to fire and the spark gets transfered from the coil to the cap then the plug the rotor is pointing at .
Old May 7, 2009 | 04:07 PM
89RESTO's Avatar
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
So then my issue lies somewhere between the coil and the ecm and not between the coil and distributor?
Old May 8, 2009 | 07:32 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
I would say it is either a bad control module or a bad pickup coil or both .
Old May 8, 2009 | 09:56 AM
89RESTO's Avatar
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Thank's 89-bird, I will pull the distributor and replace them.
Old May 8, 2009 | 09:58 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Your welcome and that should fix your problem .
Old May 18, 2009 | 07:49 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Did that fix your problem ?
Old May 18, 2009 | 08:21 AM
bubbatwo0_0's Avatar
Car: 87 iroc
Engine: five-seven L98
Axle/Gears: 3.27 aussie
I agree its sounds to me like the module, pick up or a loose connection from the coil to the module.
Old May 18, 2009 | 08:25 AM
Car: 87 iroc
The time it takes you to swap out the coil, the module would have time to cool off, therefore working again when you restart it. Heat is what makes these things break down.
Old May 18, 2009 | 11:31 AM
89RESTO's Avatar
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
So far so good, I replaced both parts with ac delco brand, I didh't want to take a chance on cheaper parts as I don't feel like pulling the distributor in a couple months or so. I took a few short trips and nothing but smoothe running. I just need a few more trips around town before I will declare it fixed, It takes a little time to gain confidence when your car could leave you stranded at any time.
Old May 18, 2009 | 11:46 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Glad to hear you got it and hope it stays fixed .
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
school boy
Oct 22, 2015 11:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
