Camaro won't start
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Camaro won't start
My car has had previous problems where it won't crank at all, there's power in the car, but it's not getting to the starter. About a month ago I used to be able to fool with the negative cable on the battery and it would sometimes cause it to crank, so I just tightened it down really hard and it hadn't given me a problem until this afternoon.
I'm really fed up with this, does anyone know if I could just wire up a switch to the pos and neg terminals on the solenoid and have it work like that? My boss' elcam is wired up like that.
Transmission: 4L80E/4L80E
If all you did was tighten the cable, you didn't solve the root problem - corroded terminals.
Take them apart, clean them up, replace if necessary. Don't go adding unnecessary wires and switches.
92camaroJoe
Aug 13, 2015 06:07 AM
