what gear
Old Mar 31, 2009 | 07:41 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
what gear
hey guys in ready to test out muy new nos sniper kit. i was wondering what gear would be better for dragging/nitrous running? overdrive or drive would be better? the car kicks *** in drive, and well in overdrive. any suggestions?
Old Apr 1, 2009 | 08:01 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: what gear
It's easiest just to leave it in drive for testing, however I always manually shifted the auto to get a few more rpms out of each gear. What rear gears do you have? Also, how big of a shot are you going to run?
Old Apr 1, 2009 | 11:12 AM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
Re: what gear
It really doesnt matter because if the tranny is stock it won't go into overdrive at WOT. Like said above, I always manually shift the auto's.
Old Apr 1, 2009 | 05:22 PM
Engine: 355
Re: what gear
im running the stock gears in the rearend, and im running a 100shot
Old Apr 1, 2009 | 05:23 PM
Engine: 355
Re: what gear
i installed the b&M tranny valve to let the trans shift at wot in overdrive, but dunno if it will matter
Old Apr 1, 2009 | 09:15 PM
turboIROC's Avatar
Re: what gear
No need for OD drag racing. At least 3.73 gears and if you dont have a posi rear get one or you will have serious one tire fire.
Old Apr 2, 2009 | 11:51 AM
Engine: 355
Re: what gear
ya im looking for gears and a posi, i hate the one wheel wonder peel
Old Apr 2, 2009 | 12:15 PM
squeeezer's Avatar
Car: 5 cars
Re: what gear
i have an 84 t/a
3000 stall
700r4
3.73 rear gear
26" tall tire i run through the traps at 6000rpm
Old May 4, 2009 | 07:18 PM
Engine: 355
Re: what gear
i tested it today and it shifts fine threw first 3 gears and gets up tp 5500rpm, and i let off fearing a kaboomer! is the rpm level right?
Old May 5, 2009 | 07:21 AM
Engine: 355
Re: what gear
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
