fuel filter location and weak spark
Old May 5, 2009 | 01:27 PM
g/f's z's Avatar
this is an 83 z28 with the 305......where is the fuel filter at?... was it on the original carb?.....another thing, it is really hard to get started and keep running, when it finally does, it wont idle and sputters and backfires when holding the gas to keep it running.......new plugs, wires coil and cap....when it wasnt starting before i checked for spark and instead of normal spark, it was jumping back down to the plug itself and was very weak, took the ign module and got it tested and was good......cleaned the connections and it would then fire......went to mess with it again today and spark is not very good at all, but enuff to get it fired up with the symptoms above^.........what else would cause weak spark?.....
Old May 5, 2009 | 02:41 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: fuel filter location and weak spark
The filter is in the QJ, where the fuel line enters. Weak spark could be a poorly grounded coul, but it sounds like you might have the initial timing too advanced.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
oops, coil, not coul
Old May 6, 2009 | 01:29 AM
g/f's z's Avatar
my g/fs dad was thinking timing also......but we drove it home back in november fine....dizzy hasnt been touched except for what ive said........which direction does it turn ccw?
Old May 6, 2009 | 02:01 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
If you pop the cap and crank the engine, you'll see the rotor going clockwise, as viewed from above. Thus turning the dizzy CCW advances the timing.
Old May 6, 2009 | 02:04 PM
g/f's z's Avatar
alright, i got it runnin.....i guess the timing was off......
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
