valve guide seals
Old May 7, 2009 | 01:43 AM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
valve guide seals
can i use intake seals on both intake and exhaust. what brand seals or part number should i use. also any tips or tricks for this job
Old May 7, 2009 | 09:51 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: valve guide seals
The reason there are different seals is the intake will pull oil past the guides while the exhaust both runs hotter and will push the oil back up the guides. The heat is why the exhaust valve to guide clearance needs to be slightly more, but still, more oil needs to get past the exhaust seals. Also, too much oil past the intake guides ends up getting burned, causing detonation, while too much oil past the exhaust guides ends up as carbon deposits on the back side of the valve, not causing detonation. I've always likes positive seals on the intakes and umbrella seals on the exhausts.
Old May 7, 2009 | 11:15 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Fel pro intakes work ok on both.
Ask at a parts store for intake seals, then buy two sets.
The part number has been posted on this forum before, I just don't remember it offhand. DO a search.
Old May 7, 2009 | 02:04 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
yep, that's a good way to spend $35, when there's good reason to not do so.
Old May 7, 2009 | 05:48 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i'm a little old school ( hell i'm really old ) , i like to use both on all valves . they are cheap , i paid less than $25.00 for the whole mess from NAPA . i'm talking about stem seals under the valve keepers & rubber umbrella seals under the springs . some say they are not needed , but what can they hurt ? i will be doing the same again soon on my latest 3rd gen when i go to roller tip rockers . when you get the valve covers off make sure the oil drain passages are clear . they are at the lower front & rear of cylinder heads . they allow oil to drain freely back to crankcase & not build-up in cylinder head . the passages do sludge up . i have been doing this on street engines more years than i want to admit . good luck .
Old May 7, 2009 | 06:10 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Technically, they're only required on the intakes but I've also used the umbrella and square o-ring seals on all the valves.
My race engine, because I use triple springs, has no valve seals. There isn't enough room inside the inner spring for a seal. It's not a high mileage engine so they're not required.
Old May 7, 2009 | 10:21 PM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
wait when i pulled mine there was only one seal per valve the intake had a press on and the exhaust had a small hard plastic o ring
Bubbajones_ya
Jul 6, 2024 08:32 PM
355tpipickup
Sep 13, 2015 11:35 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
hdis2002
Sep 8, 2015 02:52 PM
tgp1990
Sep 4, 2015 06:24 AM
