intake runner
Old May 7, 2009 | 03:33 PM
gilly327's Avatar
Car: 86 firebird se/91 camaro rs
Axle/Gears: 3:73/3:42 4th gen
intake runner
is there A formula to calculate which size intake runners and cc would fit an engine combo best? im trying to figure out the perfect match head for my set up.AFRs are too much $ and dont want vortecs thanks.
Old May 8, 2009 | 10:25 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: intake runner
sure there are formulas, but experience works just as well for this. The Vortecs will feed a 350 well enough for 400 hp at 5600 rpm with the GM "hot" cam. AFR 180cc heads will provide 450 horses at 5500-6000 rpm, TFS 195s will provide about the same, but don't catch the Vortecs until 2400 rpm, Sportsman2s never catch the Vortecs, Patriot Freedom 185s are no better and no cheaper than Brodix IK180s which surpass the vortecs, for just $700/pr. bare, et cetera et cetera.
Old May 9, 2009 | 08:58 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
Re: intake runner
Sportsman 2's have 200cc intake runners...which is alright. They are pretty cheap, which is the major convenience. I'm running those in my camaro right now...if you can do some head work those can easily get 220 cc's...even 240 with some SERIOUS work
Old May 10, 2009 | 04:50 PM
gilly327's Avatar
Re: intake runner
i pretty much had my mind set on trick flow super 23's.i happened to see one day summit had a set of heads that seemed pretty identical except the runners were 170 and the tfs are 195.i asked summit which would be better and they said the summit heads.they're both the same price so i figured id research a little more.
Old May 11, 2009 | 11:46 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: intake runner
For a 327, a 170cc head has the advantage under 3000 rpm. Above 5000 rpm, the 195 is much better.
Old May 12, 2009 | 03:54 PM
gilly327's Avatar
Re: intake runner
gonna be 350 bored .030 not 327
Old May 13, 2009 | 12:22 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: intake runner
then subtract about 500 rpm from my above figures.
customblackbird
Oct 1, 2015 04:30 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Rally Smith
Sep 14, 2015 06:59 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
