harmonic balance issue 1998 vortec motor
Old May 7, 2009 | 05:27 PM
danielmonster's Avatar
Car: 1985 IROC
Engine: lb9
Transmission: 700R4 B&M shiftkit
Axle/Gears: 3.42s
Hi. I've come into an issue as the last of my newly built motor is coming together. I ordered a chrome timing cover from summitracing.com that i'm using. The problem is that in an efi application, the crankshaft position sensor utilizes a metallic disk that goes in the stock timing cover and behind the harmonic balancer. There is not enough room for this discular shaped object that I no longer need due to my use of a carb. Not having this installed will put my harmonic balancer about .100"-.200" inch closer (estimate) to the motor. Is this going to throw my pulleys off or is there a way to solve this issue other than using the stock timing cover. Thanks.
Old May 8, 2009 | 04:44 PM
Pocket's Avatar
Car: 91 Trans Am
Re: harmonic balance issue 1998 vortec motor
You must use the vortec balancer with the reluctor ring
If you remove it (just slides off) then you must get a standard SBC balancer
There is .125" difference between the two
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Wesly_66
Aug 26, 2015 09:55 PM
86White_T/A305
Aug 17, 2015 12:16 AM
