Quick distributor question
Old May 7, 2009 | 08:49 PM
FFCam1991's Avatar
Car: 91 Formula
Axle/Gears: stock
Hey guys,
I'm updating my ignition system with new wires, cap and rotor. My question is how to get the rotor off. As I understand it, I just need to pull straight up and it should come off. I know some models have 2 bolts but I don't believe mine do. At any rate, its a 91 formula 305 and no matter how hard I pull, I can't get that rotor off.
Any responses would be great, I have it all wired up, just need to get the new rotor and cap on.
Thanks!
Old May 7, 2009 | 09:04 PM
Sledge84's Avatar
Car: '84 Z28
Engine: 383 Stroker
Re: Quick distributor question
two screws around the outside of the rotor. Should be pretty short. Pop those off and it'll flop right off.
Old May 7, 2009 | 10:48 PM
FFCam1991's Avatar
Car: 91 Formula
Axle/Gears: stock
There are no screws on the plastic rotor. The guy at the autoparts store thought it would pull right off. Tried again, still no luck.
Old May 7, 2009 | 11:14 PM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
What engine do you have? There should be screws there.
Old May 7, 2009 | 11:25 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Depends. The later CC HEIs dont have any screws retaining the rotor. Just a press-on affair. They can be pretty tough to remove after they have a chance to get rusted in place from water and corrosion. Try gently heating up the plastic base of the rotor. It may help free it up. If worse comes to worse, you can always use a chisle to crack it to take it off, just be sure you dont hit the shaft underneath and damage it.
Old May 8, 2009 | 04:43 PM
FFCam1991's Avatar
Car: 91 Formula
Axle/Gears: stock
Thanks for the responses guys.
I ended up cutting off the top part, driving a nail into the plastic collar to loosen the grip and then using a hammer to pry it off. Not a fun job.
Caspar
Jun 19, 2016 11:19 PM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
L98GTA87
Aug 5, 2015 11:02 PM
