89 Bird Issue
Old May 9, 2009 | 12:00 PM
stealthmk's Avatar
89 Bird Issue
Hello All,
I'm a newb to this forum as I'm a newb to the pontiac community. I had Recently purchased an 89 firebird that runs like a dream. However it is leaking a dollar coin sized ammount of fluid. I check often the oil and tranny fluids and everything seems to be fine. What could this be? The leak is coming from just a little past the front wheels. Thank You
Old May 12, 2009 | 12:37 PM
beatereater's Avatar
Car: 84 Trans am
Engine: 355
Transmission: TH400
Axle/Gears: 343 rear end
Re: 89 Bird Issue
It is probably your coolant. it could be a hose clamp going bad or something else. check the fluid for color. if its either brown (which is bad for some coolant) or green it is most likely that.
db057
Apr 28, 2019 07:45 AM
tglennon11
Sep 23, 2015 05:30 PM
TheTraut88
Sep 11, 2015 05:16 AM
383cam
Sep 9, 2015 06:01 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
