Rear Posi?
Old May 10, 2009 | 11:22 AM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
Rear Posi?
So the other day I just floored it and their was soo much smoke I couldn't see the tire marks on the road. So I go back and only see one tire mark on the street... I thought these things had Posi rear ends? I have a 1988 L98 GTA.
Old May 10, 2009 | 12:00 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear Posi?
A shot limited slip will act like an open.
JamesC
Old May 10, 2009 | 12:22 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Rear Posi?
Too many burnouts over the years will do that to a LIMITED SLIP. they were not designed for that type of amusement.
Old May 10, 2009 | 02:02 PM
BigBadGTA's Avatar
Engine: 350TPI
Axle/Gears: 3:27
Re: Rear Posi?
well that sucks... The car isn't beat on that often, and I hope the previous owner didn't beat on it. There is no whining at all from the gears and it drives smooth, so I wouldn't think there would be anything wrong with it. It drives like a new car.
Old May 10, 2009 | 02:48 PM
JamesC's Avatar
Re: Rear Posi?
Pop the cover and look (a decade or more has probably passed since the diff was serviced). If you have a limited slip in place and you're getting a one-wheel peel, the L/S is toast.
JamesC
Old May 10, 2009 | 03:54 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Rear Posi?
It's likely a Borg Warner 9 bolt. The cone posi tends to live a short life. Also, all the grit from the cones wearing trashes all the bearings if the oil isn't changed often. It's just not a great design (even though it's stronger than a 10 bolt). They can be fixed, but not cheaply.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
