SBC Block Casting Numbers
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
I got two motors just laying around. One came out of an old graintruck and my dad said it should be a four bolt main and steel crank.
The other one we always had, it has the "double hump" heads on it.
One engine has 3892657 on the block, the other 397001(or 7)(0?) EDIT, looking at it closer its 3970010 (pretty sure).
Anything worth while? Size would be nice to know too. Thanks guys
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: SBC Block Casting Numbers
The 010 block is a very common casting used for many years in many models and was used to make 4" bore engines such as 302, 327 and 350. It's probably the most common casting to be used in a rebuild.
The 657 block was also used to make all 3 of the 4" bore engines all in 1967.
Getting the suffix numbers can tell a lot more about the engines. Look for the stamped numbers on a pad in front of the passenger side head.
Car: 1990
Axle/Gears: stock
when you run into block casting number problems i go here http://www.mortec.com/ and for heads i keep this around in pdf form.
C409
Jan 21, 2016 08:29 PM
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
