a few electrical issues
Old May 13, 2009 | 11:54 AM
ukfirebird's Avatar
first off my interior lights are having a few problems.middle one has never worked and the ones in the mirror have decided to stay on even with the doors shut but i dont know why,ive had to dissconnect them from the mirror to save the battery,is there a relay for these?treid the bulb in the middle one but still doesnt work.
also my heater has just stopped working checked the fuse but it is ok,is there a relay for this or could it be something else
any help would be great as im new to these cars
cheers
graham
Old May 14, 2009 | 08:34 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
EN-LIGHTENING POST
Your mirror contains map lights which are also controlled by 2 switches mounted on the bottom.
Dome light ▬ find out if the hot or ground is missing.
Remove it and make sure the wiring is still connected.
If so trace it back to where the break is ▬ easy fix.
Heater blower motor ▬ if none of the speeds work connect 12 volts directly to the motor to see if it’s good.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. Keep em turned off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
Cornholio7979
Sep 20, 2018 02:31 AM
Gambit TA
Sep 1, 2015 07:27 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
mizz0313
Aug 12, 2015 06:45 AM
