kick out or not
Old May 13, 2009 | 11:55 PM
superT's Avatar
Car: 1985 camaro z28
Engine: 355 sbc what else
Transmission: TH 350 manual vb/ 4200 stall
Axle/Gears: 4:30 on the street
kick out or not
was just looking at the moroso homepage and was wondering if i should get a kick out pan or a deep sump. just wanted to know which fits the stock k-member the best. would really like to have the 7 qt pan but was afraid that the kick out's sump is to long and that the deep sump is to low to the ground?
any info on this question would be great
Old May 14, 2009 | 09:45 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: kick out or not
I run a deep sump 7 quart on my BBC that's sitting lower than stock and don't have any ground clearance issues. I run a tubular k-member that allowed me to lower the engine but even when I ran a factory k-member, the deep sump still had no problems.
Kickout pans sometimes have problems with header clearance but it depends on the style of headers. SBC usually have lots of room.
Old May 15, 2009 | 01:26 AM
superT's Avatar
Re: kick out or not
well i have hedman hedders long tubes on the motor for now and there is alot of room in between the headers. my fitment question was really about the nose to tale difference between the deep sump and kick out pan. i don't recall the exact deminsions but the difference was more than an inch and i just wondered if anyone had run it to any problems with the sump of a kick out pan hitting the k-member.
but thank you for your input, if i ever try to stuff a big block into my car you'll hear alot from me!
Old May 18, 2009 | 11:18 AM
superT's Avatar
Re: kick out or not
the actual demintion is 1/2 inch in length so i don't think it should bw a problem
junior419
Apr 7, 2025 11:35 AM
L0tuS
Oct 4, 2015 08:07 AM
Giocio
Oct 1, 2015 12:20 PM
mcbitchman
Sep 29, 2015 12:32 AM
tattmann
Sep 27, 2015 05:20 PM
