Running problems
Old May 17, 2009 | 07:03 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Running problems
Most of the time the car won't start. But sometimes it does start and when it does start idle is perfect but when you get in the 3000-5000 RPM range the RPMS jump alot. And it won't run for very long. It just stops. When I put gas into the carb it doesn't start and the TBI is getting fuel. Where should I start?
This is the 1989 Camaro 350 TBI/Standard
Old May 17, 2009 | 10:59 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: Running problems
sounds like the IGNITION MODULE going bad.
Old May 18, 2009 | 01:50 PM
JTNKTZ's Avatar
Engine: 355/350
Exactly what I was thinking...
Is this the ignition module?
Old May 18, 2009 | 03:12 PM
50bmgshooter's Avatar
looks like it have yours tested
I had the same prob and it turned out to be the coil
Old May 19, 2009 | 09:54 AM
JTNKTZ's Avatar
Engine: 355/350
Ok, so where is the ignition module?
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Sherpajames
Aug 7, 2015 06:56 PM
