Ok Need Hecka Lota Help
Car: 91 Camaro
Engine: 5.7Fl V8 350 tpi
Transmission: 700R4 Automatic
Ok just got my car running
FINALLY
but when i was replacing the pick up coil in my dist
i pulled out 2 vaccum lines
i dont know where there start or where they end
I was driving it around town a test drive of some sorts and every since i took out those 2 vaccum lines i noticted a MAJOR MAJOR lose of power. But anyway when i was driving it i was trying to see how fast i can go (shoulda just kept it nice and slow) but anyway alot ALOT of rich gas smelling smoke filled my trunk compartment and now i smell gas when i drive
and also i had to switch out my thermostat
so i took of the Throttle Body and i broke a hard plastic vaccum line
that line leads back to a cylinder behind the driver side headlights i need to know
1)Where to the 2 vaccum lines go they looked like they started under the ignition coil
2)What that cylinder is behind the drivers side headlights
3) Where to get a new hard plastic vaccum line for that
4)Is this the reason it runs HELLA CRAPPY
5)WTH is up with the white smoke
please help
FINALLY
please help
Car: 87 iroc
Engine: five-seven L98
Axle/Gears: 3.27 aussie
Re: Ok Need Hecka Lota Help
One line runs from the egr valve to the egr soleniod that is bolted to the coil mount next to the dist. And the other line runs from the egr solenoid to the bottom of the throttle body and has a t connection there that goes to the canister behind the head light
Car: 91 Camaro
Pictures with the locations of those would greatly help me. I just dont know what your referring to
rx7speed
Theoretical and Street Racing
Jul 6, 2002 03:04 PM
