100,000 Service suggestions
Old May 20, 2009 | 11:49 PM
Jenkins's Avatar
Car: 1984 Trans Am
Engine: Lg4
Axle/Gears: 3:23
Any advice is appreciated. Just bought an 89 IROC with almost 100k miles on it. I don't know the service history. It has the 350 in it. Runs strong and easily passes smog. Supposedly has been sitting for years and smokes a little on start up. Other than new fluids, should I flush engine, gas tank...
Old May 21, 2009 | 07:29 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: 100,000 Service suggestions
full fluid change is a no brainer if you have no record of service . smoke on start up normally is valve seals . if it's just a small amount of smoke & passes smog , seals may be o.k. . remove valve covers and make sure drain holes at lwr. front and rear of cylinder heads are not sludged up . this can cause oil to drain slowly back to crankcase & build up in cylinder heads . also a can of eng. flush prior to the next couple of oil changes could not hurt . almost forgot , change fuel filter , fill up with fresh gas , should be good to go . good luck .
Old May 21, 2009 | 07:41 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Originally Posted by H.O.Z28
Any advice is appreciated....
If you're going to keep it as a daily driver for years, I would change everything rubber on it. Hoses (coolant, vacuum, fuel), fanbelt, sparkplug wires.
If you see a 20 year old car on the side of the interstate with the hood up, it's always something RUBBER!
Veaceonee
Sep 29, 2016 08:15 PM
R13_Braz
Sep 18, 2015 05:00 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
64goatman
Sep 9, 2015 01:09 PM
Jk_Under
Sep 8, 2015 08:13 AM
