Incredibly rough idle at 750 rpm
Old May 22, 2009 | 12:42 AM
geehumshriber's Avatar
Hey all,
I fired up the Camaro today for the first time in two years, and the rough idle still hasn't fixed itself. As soon as you give it a little gas (say, 1000 rpm) it's very smooth, maybe due to the fact that the vibration would be so much more frequent that it becomes less turbulent.
What are some basic steps I can take towards fixing a rough idle? It's a Edelbrock 1406 on a 305 (not stock LG4/L69). Is there anything I should pay special attention to, as I'd like to fix what would appear to be a simple problem?
Cheers,
G
Old May 22, 2009 | 02:41 AM
Nub383's Avatar
Car: 94 Silverado
Engine: 383 Vortec TBI
Transmission: 4L60
Re: Incredibly rough idle at 750 rpm
A vacuum leak will provide you with a rough idle. Spray ether around you intake gasket and check all vacuum hoses.
Old May 22, 2009 | 04:20 PM
jkrustchinsky's Avatar
Car: 1982 Trans Am, 1986 Gmc sierra
I love how people think problems fix themselves if you just ignore them. Heres a few things to check,
is your check engine light on, if it is find out whats codes are stored
change your tps
IACV might need cleaning
vacuum leaks suck, find all of your vacuum hoses and make sure they are in good shape and properly fitted in the correct locations
Old May 22, 2009 | 07:02 PM
bubbatwo0_0's Avatar
Car: 87 iroc
Engine: five-seven L98
Axle/Gears: 3.27 aussie
dude above if you think a edelbrock 600 carb has a tps, iacv, or a computer for those sensors youve lost your mind. Its probably trash in the carb. Take it off the car and remove the screws holding the top on the base of the carb, then clean everything out with compressed air.
Street Lethal
Apr 30, 2019 12:14 PM
jklein337
Sep 19, 2018 06:23 PM
JHX
Aug 29, 2015 02:30 PM
86IROC112
Aug 21, 2015 07:20 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
