vacuum
Old May 22, 2009 | 04:13 PM
jlcz28's Avatar
Car: 91 z28
Engine: 5.7 tpi
vacuum
does anybody know how much vacuum a 5.7 tpi should have? And what are the two hard black lines coming out of an electrical harness at the firewall on the drivers side (thinking HVAC) and how is that all hooked up which one goes to the heater control valve and which one goes to the plastic valve that attaches to the vacuum port on the back of the plenum? or is that right at all?
Old May 22, 2009 | 04:25 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: vacuum
how much vacuum somewhat depends on your cam and your elevation, but you need at least 16, and stock could be as high as 21
Old May 22, 2009 | 09:26 PM
jlcz28's Avatar
Car: 91 z28
Engine: 5.7 tpi
Re: vacuum
it's a stock motor except that it is bored .040. i bought a remanufactured engine. would that change anything? Should I have more or less vacuum? I also have headers and a 3 inch exhaust. But it's not running well consistantly. Any body have any good pics of the correct vacuum setup for those lines coming out of the harness and that plastic valve by the map sensor.
Old May 23, 2009 | 05:38 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: vacuum
Diagram sticker should be on hood. Just type "camaro vacuum diagram" in an image web search.
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
timonator
Sep 30, 2015 12:52 PM
dusterbd
Sep 29, 2015 08:40 AM
