Which combo?
Old May 22, 2009 | 04:59 PM
paul nl's Avatar
Which combo?
First time posting here - so please be gentle.
I`m planning an engine upgrade for my car....
It`s a kitcar - 1050 kg (2300lb) incl driver, Tremec TKO transmission, sticky tyres and 3.07 LSD rear.
I like the look of TPI and like the idea of plenty of low/mid torque from the long runners. I also like the idea of smooth cold starting/running and "reasonable" mpg - running with Holley vac sec carb now.
The parts I have and want to use are.....
1 piece rear main seal 350 block (bored 0.030" over)
Vortec heads (SDPC items - for up to 0.550" lift)
Stock complete TPI set up - but will probably upgrade base, runners, throttle body and injectors
I want to run this with Megasquirt fuel and spark with edis ignition
The car is used 95% street - long cruises including 2000miles+ European driving holiday once a year. The other 5% being circuit trackdays (amateur)
I`m looking for bags of torque up to 5000 revs and for the occasional trackday maybe fitting nitrous for extra power at high revs when the TPI will struggle to supply enough air. I prefer a lumpy idle - although not really necessary.
I have a flat hyd cam fitted now, but want to upgrade to a roller hyd - the block is machined for this.
I really need advice on cam choice and static CR.
Also is it worth upgrading to a 383 stroker or will the vortecs choke the engine?
Any suggestions/ideas welcome.
Cheers
Paul
Old May 23, 2009 | 02:34 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: Which combo?
Welcome aboard!
Vortec heads and the stock TPI are incompatable. Different intake port location and different number of mounting holes. Vortec heads have raised intake runners and 8 intake bolt holes, versus standard SBC's 12 holes. You'll either need to go with an aftermarket intake, Vortec-specific. Or get aftermarket heads with a standard SBC bolt pattern.
The decision has a lot to do with the budget.
I would look for about 9.5-10:1 compression with a medium spec cam. 220ish duration @ 050" on a wide LSA. The more aggressive the cam (lumpier idle quality), the more aggresive the tune is going to have to be. Though, aftermarket EFI control will make it easier.
Just a thought, on a 383, a stock TPI would choke out the engine, RPM-wise, before a set of Vortecs. If you upgrade the base, runners, TB and injectors, it's not a stock TPI anymore.
If you're debating whether or not to keep it a 350 or go up to a 383, do you have a rotating assembly to work with, or are you going to have to get one anyway. If you have to aquire a rotating assembly, might as well go 383. They cost the same.
Old May 23, 2009 | 02:40 AM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Re: Which combo?
Really. Then why do i have a tpi with vortec heads????? i might be mistaken but i am pretty sure they are vortec heads. its on a 1992 305 firebird
Old May 23, 2009 | 02:42 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Re: Which combo?
If you have 12 intake bolt holes, you don't have Vortecs. Get a casting number.
Old May 23, 2009 | 02:48 AM
paul nl's Avatar
Re: Which combo?
Stekman
Thanks for your reply.
I knew about the differences in baseplates re vortec heads - but will probably go for an aftermarket base and runners anyway.
The budget won`t stretch as far as, say, a complete aftermarket injection system, but I realise the limitations of the stock TPI system and I want to do it right first time.
I have a rebuilt short block with stock crank and rods bored 0.030 over with 5 cc valve relief pistons. I was considering getting the block decked and wondered about stretching the budget to a stroker set up while I`m at it, mainly to upgrade the bottom end to take a healthy shot of nitrous and to be capable of any future power upgrades.
Old May 23, 2009 | 02:50 AM
paul nl's Avatar
Re: Which combo?
As I understand it stock GM vortec style tpi base is cast number 18483572.
Old May 23, 2009 | 05:58 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: Which combo?
http://www.purplesagetradingpost.com...fo/heads1.html is the link for heads and numbers.
and http://www.mortec.com/ is also a very good site.
good luck.
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
roysatikas
Sep 22, 2015 08:15 PM
z28guy134
Sep 1, 2015 11:50 PM
