Starter bolt hole cracked
Old May 20, 2009 | 10:22 PM
drumminfoolz's Avatar
Car: 1985 Trans Am
Engine: 360
I've been having trouble getting my car started and I've checked everything from wiring to timing to shims, bought a new starter, and I realized that it's because the outboard bolt hole is cracked. I didn't think that was the problem because the crack is small, but now I know that has to be it.
I was wondering what I could do to have this repaired. I don't have much money to spare right now so I hope the solution to this problem doesn't cost much. Does anyone have an idea on how to repair this?
Old May 20, 2009 | 11:03 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Starter bolt hole cracked
Is the hole in the starter or the threaded hole in the block that's cracked?
If it's the starter that's cracked, you can just replace the "nose" piece.
Old May 20, 2009 | 11:11 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Axle/Gears: 2.73 posi
What is it doing exactly?
Old May 21, 2009 | 08:45 AM
Car: 1985 Trans Am
Engine: 360
It's the threaded hole in the block that's cracked. I had an old starter on it at first. I had to put a shim on it to start up or else it would grind. Then, after a few times I had to put another shim...and so on. I bought a new starter and the same thing happened. I put one shim, it started fine 2 or 3 times, then I had to repeat the process.
Old May 21, 2009 | 06:09 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
If the block side is cracked, I think you're SOL. I don't think there's a good way to repair this. Grinding, welding, re-drilling and tapping might work, but it's a dicey proposition welding cast iron, IIRC. Got to find a real competent welder.
Old May 22, 2009 | 09:56 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Mine cracked.
I posted pictures on the forum when I was fixing mine. Vader gave me some advice.
I had my engine disassembled on a stand though, that makes things easier.
I grinded a V, then pre-heated, then welded with high nickel rod.
You can braze it shut as an alternative as well.
One other tip I used, is to use a stud instead of a bolt there. This reduces stress on the block threads. Red loctite in a piece of grade 8 ready-rod, then put on the starter, line it up very very carefully, and tighten it down.
Old May 23, 2009 | 05:05 AM
Vader's Avatar
It can be a difficult repair if done in place. A stud might work.
The problem was common on '70s high core shift blocks:
Cleaning and nickel welding the failed area, then shot peining can solve the problem:
Scrape or machine the pad flat, and you're all set:
Old May 23, 2009 | 06:43 AM
85cam's Avatar
Car: 92 RS
Engine: 396 sbc
Transmission: t5
jb weld you a stud in there! Will work I promise, been there and done that. And the 70s block are notorius for it, this is so TRUE
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
mhatfield 14
Oct 24, 2015 07:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
